MT75 quickshift
MT75 quickshift
Hi guys has anyone fitted a swedish mt75 quickshift short lever to their 4x4 saff? I just got one and ya get no instructions or dias, Ive whipped all the gear off inside the car but not too sure whats next or if indeed ya can do it from there. Dont want to just attack it and f### something up lol.
Also what are the results after fitting? Cheers steve
I have fitted a quickshift system to a 2wd MT75 (V6) but mine wasn't swedish (whatever that is)
I bet that except for the shape of the gearlinkage (4x4 is round and 2wd is a flat bar) things should be the same.
Basically:
Whip of the hearlinkage.
Remove gearshaft (a pin through bottom "knuckle") I used a thin bolt to hammer it through
Remove rubber gearlinkage gaitor (probably torn & detoriated, butr new ones still available with Ford)
Take of the flat circlip on the top side. I used two very thin crosshead screwdriver to push the ends together so it comes out, Be careful though, it's very thin and bends easily
Remove washer
Push the bottom "knuckle" out the gearlinkage
Don't forget to replace the small rubber gaitor where the gearlinkage meets the box. I forgot on mine
Puttings things back on is ofcourse reversal of the above and very straightforward. Before you put back the rubber gearlinkage gaitor (on the bottom side of the gearstick cradle) make sure everything is in order and greased because it's pretty fiddly taking it off in 1 piece again.
The result is a much more snappy feeling in the gearchange.
Basically:
Remove washer
Resident Wrestling Legend
what you have all forgotten is that you need to have access to the bit you are traying to get out int he first place
i.e. the gear selector cradle needs to be removed from the box in the first place befreo you can do any of this
and seeing as there isn't enough space without dropping th ebox, it's normally quicker to remove the box totaly, do the job in 10 minutes, then bolt the box back in again rather thanspend 5 horus trying to get bts and bobs out through various little appetures you may or may not have hands small enought o fit through
Remko GT
the little bolt that secres the linkage also has a locking tab on it and only goes in one way (you can put it in the other way around but there is a little kink i the bar to give you move movement) and this little pin and the tightness you put on it before you lock it into place reduces the amount of slop in the stick by a huge amount
Remko GT
wheelwizardrefurbs
04-08-2015 06:23 PM
