Removing main crank bolt
My mate is struggling to get his bottom pulley off his engine to do a cambelt.
He has tried nearly everything I can think of with no successm he also tried using the starter to loosen it with a bar connected (not my fav idea) but that didn't work either.
Does anyone have any good suggestions or tips on removing it please ?
Sorry I should said the engine is in the car and the rad and ic are in place so you cannot get a impact gun in there.
As a last resort I've told him to remove the lot and just use his gun
Easy, just put in fifth gear get a helper to jam thier flipper on the brakes whilst he swings with a large breaker bar/socket on the bolt, it WILL then come undone easy, you will have to remove boost hoses etc to get enough swing though.
Resident Wrestling Legend
vinegar apparently helps too
i tried the bar method on the twinkly and, with a 6 foot scafold pole, a 3/4 drive bar, mrs on the brakes and the car in 5th i was moving the car
so bricks to chock the wheels was the next option
the other thing to remember is to make sure you put even pressure on the bar as you turn it (bonnet off and standing on the slam panel i was ) but after about 15 seconds it all came loose and i had to stop myself from tumbling to the floor
you will probably need a puller to get the pulley off too
best method is shocking it open with an impact gun - the £20 12v ones for wheelnuts are superb
needs rad removing though
I think he actually started his ownthread which Tabetha posted on so I'll leave it for him to sort now.
Thanks for all the advice though
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
