RS focus calipers on a 2wd
I have a set of rs focus caliper with discs and pads ready for my 2wd, I have ordered the brackets I was just wondering if my brake pipes will fit or i have to get different ones made up?
Anyone else got these on there cosworth ? Is it any better?
Live long and prosper!!
Rally Design order
1 metre euroquip 600 hose @ £3.50
2 x 20 degree banjos m10x1 @£2.40 each
4 x copper washer @ £0.15 each
2 x banjo bolts m10 x 1 20 or 25mm long (measure yours)@£0.80 each
2 x male convex unions@ £2.40 each (m10 x 1)
fit um together JOB DONE
Or ask BROM to make u some up
Originally Posted by dojj
i'm not sure that you'd need to keep the bano joints though, could you not just put a normal brake pipe end on there?
has anyone does this before?
I would myself look at the cossie set up and try to get as close to this as poss
Tabetha Welcome back
FlashRS
13
31-08-2015 06:02 PM
