Cossie 4x4 brakes n abs
Received 1,042 Likes
Hi there ive fitted front n rear pads 2 my car a few days ago n ive replaced drivers side front wheel bearing a few weeks ago. Since fitting the wheel bearing the abs light used 2 go off when driving. As soon as u went over about 20mph the abs light used 2 come on n when pressing the brakes when driving slow it feels like the abs is kickin in. The pedal goes hard i cleaned the drivers side front abs sensor n the ring on the drive shaft the light goes off now but the pedal is still the same. Ive noticed the passenger rear caliper hand brake lever is sized causing the brakes 2 stick on the passenger side rear. Cud this b the fault with my pedal. Any help wud b greatful thanks.
Jack and the Beanstalk
09-08-2015 07:03 PM
Red_bull
09-08-2015 08:34 AM
