cossie lsd's
Old 10-04-2007, 01:56 PM
shanemc
shanemc's Avatar
Default cossie lsd's
is there a difference between the 2wd and 4wd rear diff,and would you know the difference by looking at em?not sure whats in my car,it was originally a 4wd but converted to 2wd.
thanks,
Shane
Old 10-04-2007, 06:59 PM
Not 100% sure but thought the 4wd diff was 1/2" narrower at 7", as opposed to 7 1/2" for 2wd ?
Old 10-04-2007, 08:52 PM
CosKev3
CosKev3's Avatar
Correct
Also driveshafts/diff output flanges are bigger on 2wd,soz can't remember sizes
Old 10-04-2007, 09:53 PM
dojj
Resident Wrestling Legend
dojj's Avatar
2wd ones are 7.5inch and the 4wd ones are 7 inchers
plus the 2wd output flanges and driveshafts and hub flanges are bigger (108mm) than the 4wd itrems (100mm)
the 2wd ones also came with T45 torx bolts to hold the driveshafts in place whereas the 4wd ones used T40's, but later on ford only supplied T45's as replacements so perhaps not such a good reference point
Old 11-04-2007, 07:06 PM
shanemc
shanemc's Avatar
thats great cheers lads.i assume the 4wd rear diff is an lsd unit as well?
are both units interchangeable,i.e. can i fit a 2wd lsd into a 4wd rear end,are the mounting points etc the same?
Shane
Old 11-04-2007, 10:12 PM
CosKev3
CosKev3's Avatar
Shane
No,the beam is bigger for the 2wd,diff is 1/2 inch wider
Old 12-04-2007, 05:49 PM
I think they most likely used the same beam, and spacers to suit narrower diff, just measure it before anything else, can't see them tooling up for 1/2" as this is not big!!
Old 13-04-2007, 07:58 PM
shanemc
shanemc's Avatar
nice one cheers
Old 15-04-2007, 01:11 PM
shanemc
shanemc's Avatar
ive been offered an escos rear diff,is this the same as the 4x4 saph rear diff?
Old 15-04-2007, 02:07 PM
I am sure they are the same.
gcfcos
59
06-10-2015 05:04 PM
dalmarshall
Ford Classics & Vintage
01-10-2015 06:46 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: cossie lsd's
