header tanks
header tanks
Does anyone know if the standard 2wd sapphire header tank is the same as the 4wd one? as i can only find 4wd one for sale and i have a 2wd. cheers for any help you can give.
If your on about the Stainless Steel header then i have a 4x4 on my 2wd As for the extra outlet i have used that for my swirl pot But you can just blank it off like you would for a Dump Valve
As for the Above about the turbo water pipe dont worry about that as your hose will fit in the normal place the 4x4 turbo has the hose going around the front of the car and to the turbo on the right hand side Your 2wd comes out over the top of the engine
Heres a pic of my header tank
If you're talking about the standard plastic ones then dakar is basically right. The 2wd has a small diameter inlet above the 'max' line for the turbo return pipe - about 8mm I.D., whereas the 4wd has a 16mm I.D. inlet below the 'min' mark.
Changing from one to another would need a step up or down in pipe diameter. Not sure what the significance of the different inlet heights is though - anyone else know?
The 4x4 doesn't have the position for the water level sensor... but its blanked off on the saphs anyway. Ford still do the hose and can supply a new tank. They will supply the replacement pipe as it is an official mod on the microfische mate.... or web page these days (showing my age there).
Originally Posted by jon@work
[/panto mode on] oh no you don't [panto mode off]
