F super codes read p132b and B2296
So i got my F super today.
Amazingly i got a few codes that the workshop scanner did not!!
Airbag code is B2296 restraint system-impact sensor fault5965,59765958,5975 and it also said low battery voltage on the airbag section.I cleared the code and the battery voltage error went but the other one remains.
On the PCM page i got p132B which i havent researched yet.
I also read the injector codes and they all tallied up with the sticker on the cylinder head except for number 4.But when i looked,Injector 4 has a sticker on it which has the code that the f-super read,so i am guessing its had an injector on cyl 4 at some point.
Is there any need to recode injectors if all the codes are showing correct?
Quite interesting that a 15 quid scanner,read a code that the multiple thousand pound scanner could not
07-10-2015 12:56 PM
