st225 cv joint tsb fix??
Does anyone know what ford uses when doing there warranty tsb fix for clunking on focus st225 cv joint to hub. it is a glue of sorts but cant find info and ford won't tell me. The noise is only when taken off or reverse and ford had a technical bulletin for the dealer to fix it.
p.s. posted in wrong section so this is a re-post in correct section!!!
Well thats it once again sorted got equiv to loctite 638 cost Ł8 for 50 ml wich is enough for ten but thats all they had. New bearing too so no Knocks or rumbles
Thanks
Thanks
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
Cos500
16-09-2015 09:50 PM
