How do I fit an oil catch tank FRS
as above, anyone know which tube I should connect to?
Tried to use the tube that is coming from the inlet mainfold and goes to the white check valve and then to a steel pipe, I connected my new tubings right between steel pipe and check valve, made the turbo to only boost 0,5bar
If it's what I think you're meaning. You'll need an adapted to fit in your black ( will pedley racing sold them) this fits in the front of the block. Then run a pipe from that to your catch tank and a pipe from your rocker cover, job done
RobbieBambino
13
19-09-2016 07:09 PM
BMrider
17-09-2016 03:23 PM
