Idle problem Focus RS mk1
Old 29-01-2015, 06:17 AM
LefkadaRS
LefkadaRS's Avatar
Default Idle problem Focus RS mk1
Hello, once and a while when i start my rs it doesn't idle right or it cuts out.Solutions?
Old 30-01-2015, 09:31 AM
RSRick3290
RSRick3290's Avatar
ICV, its a pig of a job as its very difficult to access most people take the inlet off as its easier
LefkadaRS (30-01-2015)
Old 09-02-2015, 07:20 PM
Ally Young S1
Ally Young S1's Avatar
Try this first - buy a can of carb cleaner and take of the throttle housing and top boost hose off. Carefully with a wipe clean out as best you can all the carbon (make sure to be extra delicate with the throttle flap). Then spray a liberal amount down down into the inlet and spray and coat everything inside. Leave for an hour or so and then start it up, might be a bit of white smoke as it burns all the carb cleaner off.
Worked for me and all for about a £5
Old 01-03-2015, 07:28 AM
LefkadaRS
LefkadaRS's Avatar
Thanks for the info...Is it possible to tell me the exact location of the ICV?If you can a pic?I want to change it myself.
Old 01-03-2015, 10:09 AM
Fezman1
Fezman1's Avatar
I had the same symptoms. ...was worse when less thank half a tank.
My fuel pump was on the way out. (a common fault)
A dw65 later and she starts on the button every time. regardless of fuel level.
Old 16-03-2015, 10:25 PM
nigs
nigs's Avatar
had the same problem with mine and tried the carb cleaner worked a treat
salsheikh
Ford Focus ST Parts for Sale
06-10-2019 07:56 PM
Johnsie
Ford Focus ST
08-09-2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
20-08-2015 12:22 PM
saph in dorset
14-08-2015 10:10 AM
Zoggon
10-08-2015 10:39 AM
Quick Reply: Idle problem Focus RS mk1
