Wierd Noise on Boost
Old 24-03-2006, 10:48 AM
Dan_FRS
Dan_FRS's Avatar
Default Wierd Noise on Boost
I have posted this on FFOC - http://www.ffoc.co.uk/forum/viewtopic.php?t=114482
People have the same problem but no one knows what it is, anyone know whats going on?
Under full throttle i get a high pitched squeel/Beep noise coming from either the wheels or under the bonnet. I sounds like it does it when the diff is trying to get the power down.
Any ideas guys, ford are no help at all.
CheeRS
Dan
Old 27-03-2006, 07:28 AM
JamesS2RS
JamesS2RS's Avatar
I have the same.
Old 27-03-2006, 09:43 AM
NathR
NathR's Avatar
So do I, and just about every non standard I think, wouldn't worry about it.
Old 27-03-2006, 11:22 AM
JamesS2RS
JamesS2RS's Avatar
I no this sounds strange but mine only done it after the manifold was fitted
Then my boost controller went tits up so ive had no boost so i ant herd it for ages.
jim
Old 27-03-2006, 02:54 PM
focus kev
focus kev's Avatar
mines now doing that cant sus it out as its just had blue flame exhau st and manifold and a livemap and before running on standerd manifold scorpien exhaust and bluefin it was fine ?????
Old 08-04-2006, 09:33 PM
Focus_RS1658
Focus_RS1658's Avatar
I only get the sound when i run with 18psi or more, if i run less boost you can't hear it..
Old 10-04-2006, 09:34 AM
Dan_FRS
Dan_FRS's Avatar
Default Noise on boost
Took my car to Steve Hill Motorsport and took soomeone out in the car.
As soon as he heard the beep, he said Air Leak. Check the intercooler and boost hoses. He also said to check around the recirc valve.
Going to get it serviced there and i will get him to find where it is coming from. Will let you guys know when i do
Dan
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
gingeRS
17
02-10-2015 09:42 AM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Wierd Noise on Boost
