Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2.0 tdci 2006 shudder in first and second gear at low revs
Old 29-05-2013, 05:32 PM
carl/tdci 2.0
carl/tdci 2.0's Avatar
Default 2.0 tdci 2006 shudder in first and second gear at low revs
hello all
I'm having a small problem with my car atm.
When pulling away in first and also beginning of second gear the car seems to judder/shudder/wobble (all seem like a valid description lol)
Everything seems to be fine after 1400-1500ish rpm and all other gears are fine and still seems to accelerate like it should.
just thought I would pop on here and see if anyone has some ideas as to what it could be, before I take it to a garage and get a massive bill I cant afford atm lol
thanks for your time
regards, carl
Old 25-08-2013, 04:02 PM
Colin N
Colin N
Colin N's Avatar
Sounds like dual mass flywheel fooked
Old 25-08-2013, 08:09 PM
uruk hai
uruk hai's Avatar
Sounds plausible ?
To the OP, does it make a rattling slapping type noise when you start it up or switch it off ? You would also notice it if you allowed the car to labour a bit in second gear.
Old 28-08-2013, 03:00 PM
carl/tdci 2.0
Thanks for reply guys, issue was a air leak in the fuel filter housing, was getting air in the lines, not much but enough to cause problems.
New filter and seal has sorted thing out and car is running like it should again.
Man do I love the torque, haha
Thanks again
Old 04-09-2013, 07:16 AM
Colin N
Colin N
Colin N's Avatar
Glad it's sorted Carl
I have a 2.0 tdci as my daily car and I love it, I was warned about the problem they suffer with the duel mass flywheel as I am told these are similar symptoms
Yours was defiantly an easy fix, great cars and yes the torque is fantastic
Tank Mike
Ford Focus Diesel
23-02-2022 06:09 PM
TPM961
15-01-2018 10:50 AM
BENJAMIN_21
Ford Fiesta
17-09-2015 08:58 AM
landaqmabba
15-09-2015 07:16 PM
talon1
15-09-2015 10:27 AM
Quick Reply: 2.0 tdci 2006 shudder in first and second gear at low revs
