Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Best way.. Updated. (PICS)
Old 08-03-2014, 07:05 PM
pixellcraig
pixellcraig's Avatar
Default Best way.. Updated. (PICS)
What's the best way to remove rear springs from focus?
Just grind them?
Old 08-03-2014, 07:17 PM
CosworthGuy
3dr Cosworth owner
CosworthGuy's Avatar
Thats a quick dangerous way. Id say remove top and bottom shocker bolts remove strut and remove spring
Old 08-03-2014, 07:19 PM
pixellcraig
Cheers pal.
Old 08-03-2014, 07:33 PM
GVK.
GVK.'s Avatar
Lower shock bolt off, then you really need spring clamps to compress the spring, they are quite long springs and not great to get out..
If the other bottom arm bolts came out easier you could take them out to drop the bottom arm down further, but generally they're seized in.
These are seperate spring/shock on rear of Focus, not mcpherson struts.
Old 08-03-2014, 08:00 PM
Colin_P
Colin_P's Avatar
The problem with the Focus rears is that you cannot get normal DIY standard spring compressors on the spring as the subframe and lower arm gets in the way.
If you can beg steal or borrow a 'duck bill' compressor it is easy. Problem is with them they cost a fortune.
On mine, I used brute force to get the old springs out, couple of big long levers.
The new ones though I needed to take some car as I didn't want to scratch them. I know you are all going to piss yourselves and it was as dangerous as fuck but I did this...
Compressed it with my DIY threaded compressors, put the spring in (still a bit of brute force needed) and then cut the ties!
If you are just bodging the old spring in and out and dont give a monkies about damage then brute force alone can win!
Old 08-03-2014, 08:13 PM
GVK.
GVK.'s Avatar
We use this type at work.
Old 08-03-2014, 08:21 PM
pixellcraig
These look good. What's the price on these?
The spring compressors i have are to bulky and won't fit the rear :/
Also, which bolts on the rear are seized?
Old 08-03-2014, 08:22 PM
pixellcraig
Could possible be used as weapon
Old 08-03-2014, 08:53 PM
RichieST
RichieST's Avatar
Easiest way I have found to do them is put the spring clamps inside the spring, up through the hole in the bottom arm. Need to be careful though as the hooks on the clamps will now be pointing the wrong way so might ping off the spring.
Old 09-03-2014, 07:19 PM
pixellcraig
Managed to do it all myself! The rears wasn't a massive headache, managed to do both rears in hour and half.
I just used the old shock to wedge it out a little then clamped it spring compressors on the in and outside of the spring. then got a friend to stand on the rear disk then pulled it out.
New springs went in really easy and torquing everything back up was a doddle. Only one seized bolt but managed to get the bugger out.
Old 10-03-2014, 08:55 PM
pixellcraig
Didn't realise how low it would go...
Old 26-04-2014, 11:46 PM
H3lsing
ffoc.co.uk
H3lsing's Avatar
Hey looks like my own a bit. I've only gone 30mm on eibachs and blistein b4 springs. They really firm up the ride but the handling is awesome. I was out too far at a junction so had to get a new bumper but all back together now it wasn't that bad tbh.
Before:
After:
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
griffo69
04-10-2015 11:58 AM
locum8
01-10-2015 01:50 PM
Quick Reply: Best way.. Updated. (PICS)
