Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
mk4 fiesta rear bushes
Old 15-05-2015, 07:13 PM
simon2781
simon2781's Avatar
Default mk4 fiesta rear bushes
Evening, classic story, bought a lemon! Ive been a fiesta owner for 4 years, then it died, engine started knocking really loudly, so bought another fiesta, didnt realise it only had 3 weeks MOT left, I'm an idiot, anyway, needs new rear pivot joints (bushes), my question is.... Is it worth doing yourself? What kind of problems can I run in to? Apparently, you jack up the rear, axel stand it, then take off rear wheels and then lower/raise the rear axel with a jack until its easy to pop out the rear bushes, but that seems way too easy!!
So I'm after any advice that can be offered etc.
Many thanks in advance.
Old 16-05-2015, 11:42 AM
Moderator
STeve's Avatar
these are ultra common but as real pig to do, my mate who owns a large mechanical workshop did mine and said it was a terrible job to do even with the correct bush pulling tool and one side even broke his snap on tool which he was crying about, can be done DIY but dont expect it to be easy as a club hammer and a chissel will be needed big time
Old 16-05-2015, 05:41 PM
simon2781
simon2781's Avatar
Originally Posted by 1-PD
these are ultra common but as real pig to do, my mate who owns a large mechanical workshop did mine and said it was a terrible job to do even with the correct bush pulling tool and one side even broke his snap on tool which he was crying about, can be done DIY but dont expect it to be easy as a club hammer and a chisel will be needed big time
Thank you for the reply, I used the cold chisel and hammer to prize it out! Oh my goodness it took near on 2 1/2 hours to get both sides out, then I tried to put in the new bushes!! That's even harder than getting them out!! I had to give up today, arms are hurting so much from all the hammering! I am trying to borrow a tool to put the new bushes in, but I'm not holding much hope.
Old 18-05-2015, 04:44 AM
daisydad
daisydad's Avatar
Gotta do these on mine too I see the poly bushes come in 2halfs I know cost more but hoping there easier to fit.
Old 20-05-2015, 05:29 AM
simon2781
simon2781's Avatar
I can only wish you luck!! So with hammer and chisel it took 4 1/2 hours to remove both sides, and then after asking around loads I was able to borrow a bush removing and inserting tool which took me an hour to get in both sides, still hard work, had to use the 2 spanner trick for extra leverage! Still, after all the hassle, I've saved at least £200 in garage labour costs
Old 20-05-2015, 06:40 AM
Moderator
STeve's Avatar
told you they were a bad job, but when refitting with poly bushes the installation is a doddle which is the only plus side to this job
Old 20-05-2015, 07:43 PM
simon2781
simon2781's Avatar
Dude I didnt realize how hard it would be! im sure with an air impact gun it wouldve been easier hehe.
Just the welding to get done now and it should sail thru MOT I do love being able to save on garage fees.
Old 21-05-2015, 08:57 PM
I did the bushes on my puma over a year ago and the nsr bush is worn and knocking. I did it on a ramp at work and only took me a few hours.
Old 22-05-2015, 06:14 PM
Moderator
STeve's Avatar
its a frustrating job as it should takes minutes but ends up taking hours
Old 23-05-2015, 03:09 PM
simon2781
simon2781's Avatar
I can imagine that with an air impact gun it could be as little as 20mins a side with little effort. Its a job I'm not looking forward to ever again tho haha.
Its a really enjoyable feeling fixing your own car. Might think about other things like swapping to a performance air filter etc, but better check insurance first as I can imagine it ramping up the price.
Old 24-05-2015, 07:14 AM
Moderator
STeve's Avatar
better off with a decent panel filter as most cones offer no improovements and if anything make your car burn more fuel for no gain and then you dont need to inform insurance
Old 28-05-2015, 10:44 PM
simon2781
simon2781's Avatar
oh is that right? so people normally fit a performance air filter for cosmetic enhancement? glad you said that, thanks!
Old 29-05-2015, 07:34 AM
Moderator
STeve's Avatar
noise and cosmetics mate, 80% of them draw in heat which makes car run worse too, on performance cars like cosworths and turbos etc look where the filter is mounted right at front of engine bay far away from engine for maximum cold air intake, these silly little ducting pipes without vent holes etc do sod all
Old 30-05-2015, 12:57 PM
I fitted a cone filter to my puma and it feels more responsive. I made sure I had a good cold air feed going to it.
Old 11-07-2015, 09:09 PM
Wardy ZS
Wardy ZS's Avatar
Easiest way to remove the bushes is burn them out.
Then use a hacksaw to cut the sleeves. 10 min job once the beam is off.
09-10-2015 07:38 PM
skypeller
19-09-2015 09:58 PM
TrevCos
17-08-2015 09:08 PM
track.focus'd
12-08-2015 05:53 PM
Bosch
04-08-2015 05:14 PM
Quick Reply: mk4 fiesta rear bushes
