Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Help with replacing original mk2 stereo
Old 13-02-2015, 03:05 PM
Danielchristian
Danielchristian's Avatar
Question Help with replacing original mk2 stereo
Hi guys,
Can someone please explains me how to remove the original stereo from the dash on my 1985 mk2 fiesta?
I can't see any pins on the stereo where you would normally insert the removal keys - the guy at halfords said it would be a case of removing some of the screws in the dash to get it out. Any tips/pictures would be much appreciated!
If it helps the stereo is on the bottom part of the dash - ie. Just in front of the base of the gear knob. It is the factory fitted radio only stereo.
Finally, I am also looking to locate a stealth shelf for my new speakers as I don't want to bugger the original parcel shelf if possible.
Many thanks,
Dan
Old 15-02-2015, 04:02 PM
BobbyTaylor93
BobbyTaylor93's Avatar
I'm having the same thoughts haha I've got a 1985 1.1 dash model and it's got the same radio as you by the sounds of it haha gonna investigate soon, do you know what wiring adapter we need?
Old 22-02-2015, 06:04 PM
minder
minder's Avatar
all you need to do mate is use a flat blade screw driver
and gently prize it out as for the shelf just replace it
with your new one
Old 05-03-2015, 04:12 PM
Adam592
Adam592's Avatar
Sounds similar to my one.
If you remove the volume/tuner dials there are some bolts you need to undo.
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
gingeRS
04-09-2015 06:29 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: Help with replacing original mk2 stereo
