Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Mk6 Fiesta 1.4 TD advice?
Old 18-01-2015, 03:33 PM
saul
saul's Avatar
Default Mk6 Fiesta 1.4 TD advice?
Hey how's it going, I'm buying a Mk6 Fiesta in a few days and looking some advice about it
It's advertised as a 1.4TD ZETEC CLIMATE 5door
It's year 2007 with 75k miles
I don't know the engine code or anything specific like that
I'm new to the ford game so I have a few questions..
1) what's the difference between TD and TDCI?
2) what does Zetec and Climate mean?
3) just by doing a small bit of research on the 1.4td, a lot of people seem to have needed the injector seals replaced, is this a common problem and is it expensive? How often in terms of mileage do they need replaced?
4) are there any other common faults/things to look out for with these engines or cars in general?
5) I noticed when I went to start it the glow plug indicator light didn't come on even though it was quite cold (icy) outside so does anyone know the minimum ambient temperature before the glow plug indicator light comes on?
6) I'm used to v/ag tdi's and noticed that the fiesta didn't rev quite as quickly from idle in neutral as the vw tdi engines did. Is this to be expected? It might be because it was cold
Sorry for all the questions I just wanna learn :P anyway thanks in advance for reading any help appreciated
Old 18-01-2015, 05:17 PM
oldford
oldford's Avatar
With a lot of diesels the glow plug light is also used as a fault lamp.
I would start by having the codes read with a Ford specific scanner.
Maybe someone disconnected the glow plug light for some reason.
Old 18-01-2015, 05:34 PM
saul
saul's Avatar
Cheers for the reply, so are you saying it is normal for the glow plug lamp to not show up on the dash when the ignition is turned on? And is there any cheap or free ford obd software out there?
Old 19-01-2015, 03:05 PM
oldford
oldford's Avatar
No, on the contrary, I am saying that I expect the glow light to be on for a short time to signal that it is still working.
Have a look here for software: http://forscan.org/home.html
Old 20-01-2015, 10:34 PM
saul
saul's Avatar
Cheers bud I will check it out
rex647
06-03-2022 06:20 AM
Maxwell
Fiesta ST
13-09-2015 05:31 PM
fordfiestamk3
11-09-2015 12:52 PM
28
08-09-2015 07:10 PM
andrewmctiernan
08-09-2015 03:05 PM
Quick Reply: Mk6 Fiesta 1.4 TD advice?
