Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Mk 3 fiesta rear disk conversion can it be done
Old 27-06-2014, 04:34 PM
joeb
joeb's Avatar
Default Mk 3 fiesta rear disk conversion can it be done
Rite I've got a mk3 Feista and want to convert rear brakes to disk can this be done if so how ???
Old 27-06-2014, 04:44 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
I believe people use a Focus set up for rear discs, not sure on the details though.
Old 27-06-2014, 04:58 PM
joeb
joeb's Avatar
Cheers man ill have a look into it
Old 27-06-2014, 08:51 PM
shalon
shalon's Avatar
mk5 axle with focus stubaxles and carriers calipers etc
Old 29-06-2014, 05:24 AM
joeb
joeb's Avatar
Cheers pal
Old 29-06-2014, 11:39 AM
XR2
XR2's Avatar
MK5 means Fiesta 99-02.
MK6 (02-08) won't fit.
Old 29-06-2014, 12:37 PM
joeb
joeb's Avatar
Mk5 fiesta is still drumbs on back really wanna run disks
Old 29-06-2014, 01:07 PM
XR2
XR2's Avatar
as above. 99 Fiesta rear axle with Focus MK1 parts.
Old 29-06-2014, 04:15 PM
joeb
joeb's Avatar
Ohhhh I see that makes sense now
Old 29-06-2014, 07:41 PM
Oranoco
Oranoco's Avatar
You will also need to add in some bias valves to take away most of the braking effort or the first time you stamp on the middle peddle it will be like yanking the handbrake.
The drums are perfectly up to the job of stopping a Mk3 Fiesta so I would leave well alone. Even my mates 400bhp Zetec Turbo is still using the drum setup on the back
Old 29-06-2014, 07:49 PM
dakar
dakar's Avatar
Can you not fit em to a mk3 beam?
Old 29-06-2014, 09:02 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
As above, drums are more than capable in a light car like a Fiesta. If you are adamant about upgrading then you could possibly look at the bigger drums that came on later Pumas, I'd imagine they'd fit without much hassle. Also be worth getting hold of a Mondeo master cylinder.
mint_s2
02-09-2015 08:58 AM
atm
01-09-2015 04:56 PM
RsS2daz
14-08-2015 05:26 AM
Bosch
04-08-2015 05:14 PM
Quick Reply: Mk 3 fiesta rear disk conversion can it be done
