anti lag question
Old 28-03-2016, 04:04 PM
fitzpodge
Podge
fitzpodge's Avatar
Question anti lag question
hi all,
i am in the middle of fitting some new parts to my engine and stick on the dyno and wondering if it will be safe/worth fitting anti lag while I'm at it???
its a fiesta rst engine EFI
T3 hybrid
big actuator
kent 34 cam
scorpion exaust
airtec rad
big front mount intercooler
omex 600 engine management
standard rst pistons
will it be a big job to do this or do i run the risk of wrecking my engine ?
Old 28-03-2016, 05:57 PM
adam151082
adam151082's Avatar
as far as I'm aware the only real damage is to the turbo and that will need a special shaft
Old 28-03-2016, 07:00 PM
visa_broke
visa_broke's Avatar
marium (or however its spelt) from memory
Old 28-03-2016, 08:55 PM
botters
competant bodger
botters's Avatar
mar-m247 to be specific
Old 28-03-2016, 09:04 PM
fitzpodge
Podge
fitzpodge's Avatar
Question
Thanks
i have a Garrett T3 rebuilt and hybrid internals put in so would that be ok instead of opening it again for that shaft ??
i only want to use this anti lag for recreation, not going to be used every day or on any tracks. I would only use it for car shows and the likes..maybe a track day once a year or in a blue moon ???
Old 28-03-2016, 09:05 PM
botters
competant bodger
botters's Avatar
it should be ok to use just bare in mind it will shorten the life of the turbo quiteabit
Old 28-03-2016, 10:30 PM
jessie_rs
jessie_rs's Avatar
I used it alot on my old series 2, fantastic fun but forever destroying exhaust manifold gaskets for some reason
Old 29-03-2016, 03:12 AM
fitzpodge
Podge
fitzpodge's Avatar
great so i reckon i will go ahead and start looking into it to get it done !
so if its an EFI engine with OMEX 600 management and a good turbo, what other parts will i need to get the job done? and is it going to cost a small fortune to install? I'm not sure whether its going to be a massive job to install ?
thanks again!!
Old 01-04-2016, 03:25 PM
Karl @ FPT
Always a pleasure!
Karl @ FPT's Avatar
I'm not familiar with OMEX but assuming it supports it you will need to modify your inlet manifold/throttle body and have some sort of air bypass valve fitted too.
Old 01-04-2016, 04:49 PM
gjh
gjh's Avatar
Cant imagine its easy to get hold of a Mar-m247 shaft these days, seen the odd one for sale but they were very expensive.
Old 04-04-2016, 07:06 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
In all the years I have been building systems from budget oxfam to life racing, very few of the cars have used a 247 shaft. None of them destroyed the turbo from overuse of ALS.
Unless you are building a full on track or race car you wont need expensive turbo.
Old 04-04-2016, 07:38 AM
R4N SS
R4N SS's Avatar
Omex will run anti-lag fine mate but as said you need to get the ALS valve or get your valve modded
Gem frst
18-04-2016 10:24 PM
Rsturbo519
22-02-2016 07:23 AM
bluntys1rsturbo
Fiesta RS1800/RS Turbo
18-02-2016 04:43 AM
bluntys1rsturbo
15-02-2016 06:26 AM
Tommy777
10-02-2016 09:46 PM
Quick Reply: anti lag question
