Which ECU is this? And is it Healthy? :O
Fresh out the Pyrex pot!
Hi, I have an ECU and a knock sensor engine... Is this compatible? Also I'm curious about the 'missing bolt' holes on the circuit board in the second image... Lemme know if it's good to use!
Also what is the little breather spout for? And does it need a hose on it to go anywhere?
Any help would be great, thanks!
Mad_Mat (24-03-2016)
Yeah looks like it, because of that T-piece ayy? Dump valve and ECU going in there... Looks like the answer thanks!
Is that your engine bay, before the zetec?
Always a pleasure!
Yes that ECU is compatible with the knock sensor, it is fitted with a superchip (as I'm sure you can see lol) and as Stu has said that's the MAP sensor hose fitting and should be connected to the inlet manifold directly.
jdsjojo
21-03-2016 10:24 AM
