Compression struts fitting
Old 08-03-2016, 09:31 PM
russ rs
russ rs's Avatar
Default Compression struts fitting
Hi
Has anyone got any measurements of where the base plate needs fitting on a mk4?
Take it got cut out the chassis rail?
And any photos if possible
Thanks
Old 09-03-2016, 05:27 AM
gus
gus's Avatar
Mine go from the arb corner plates into the tca
Can't find a pic of it
Old 09-03-2016, 11:54 AM
nigel b
nigel b's Avatar
if you are gonna use ones that go onto the chassis rails stu collins should have some pics,his was like that
Old 09-03-2016, 12:49 PM
davidfox280585
davidfox280585's Avatar
mk2 escort kit would fit a escort and weld to chassis legs, considered this myself then use a mk2 arb with rose jointed drop links
Old 09-03-2016, 04:39 PM
gus
gus's Avatar
Do front and back mounted jobbies work equally well?
Seems a no brainer if so. Mount from the front as it's the easiest option
Mine is and I have a arb all on rose jointed drop links for adjustment
Old 09-03-2016, 05:35 PM
muz
Wye Valley Hardcore
muz's Avatar
Just out of interest, why do you want to use that sort of set up?
Old 10-03-2016, 12:02 PM
nigel b
nigel b's Avatar
back mounted is usually better,think of the force on the tca when accelerating
what do a/r/bars work like
Old 11-03-2016, 01:57 PM
russ rs
russ rs's Avatar
Going track antidote bar crap can't find 16i rollbar and car still on spit so works well on the mk1 so thought see how is and stu reckon his work fine.
Sam_RSi
Escort Range
01-08-2016 07:13 PM
James Porter
29-04-2016 01:27 PM
lockie
07-03-2016 05:02 PM
kingflipper
Ford Fiesta
06-03-2016 08:07 PM
kevin micallef
06-03-2016 05:36 PM
Quick Reply: Compression struts fitting
