Rs turbo gaskets
21-06-2015, 09:51 AM
The posh are up!!!
Rs turbo gaskets
I need a EFI throttle body gasket, where can I get one from?
21-06-2015, 12:48 PM
I see you've been a forum user since Dec 2007, So therefore im 99% sure you've tried getting one from Burton Power. If so I can assume you've also tried eBay and Ford directly?
21-06-2015, 05:16 PM
The posh are up!!!
Waiting on ford bud, need it for my cosworth management conversion
21-06-2015, 05:24 PM
Are they not just a paper gasket?
21-06-2015, 05:33 PM
Quote:
Originally Posted by
Chopshop85
yes they are mate, i couldn't find a gasket for mine so just bought some good quality gasket paper and made my own and it does the job fine
21-06-2015, 07:15 PM
Ford will do it. If you want to ebay it I'd recommend gaskets for classics
21-06-2015, 07:32 PM
If you are fitting cossie management are you not using a cossie throttle body?
21-06-2015, 09:07 PM
The posh are up!!!
Good point so just use a Cossie throttle body gasket?
21-06-2015, 09:14 PM
AJ-RST1
Yes exactly that, I presume your inlet has been modded to suit the cossie t/b?
plenty of cossie t/b gaskets on ebay.
21-06-2015, 09:36 PM
The posh are up!!!
Tbh with us I thought the inlet and throttle Body was a fiesta, I got the kit with the inlet and t/b built up. I'll get a Cossie one then.
RSBryden
06-09-2015 08:39 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
