Mk3 mondeo brakes what braided lines?
Resident Wrestling Legend
standard lines when i did mine
if you use the mondeo ones they are too long as i found when i did this on my fiesta
i took some pics when i redid them last week so i'll stick them up in a bit, no need for spacers i found other than the ones i used to make sure the mk6 wheels would fit as they are a different offset to the mk4 fiestas
Fleet Manager
I'd of thought any engineering shop would be able to knock you some up I think I used 25mm diameter bar, drilled it up the middle & then parted them off at the right length.
Mark.
Dr. Ickxs
15-09-2015 10:15 PM
