got mondeo mk3 callipers struggling with bolts
Old 19-10-2014, 07:34 PM
tlr_rst
tlr_rst's Avatar
Default got mondeo mk3 callipers struggling with bolts
following the guide on this forum
today picked up mondeo mk3 callipers and new pads, just need to get focus st170 discs.
im struggling with the spacer and the bolts, there isn't much information on this.
i read 12mm is need is that right?
don't know anything about the bolts so would really need some help
it will be going on standard 15" escort turbo turbine wheels with some grinding hopefully
Old 19-10-2014, 09:09 PM
marky_g
Fleet Manager
marky_g's Avatar
I struggled with this you will need a 12mm spacer you need to drill out the hubs and you need m12 Bolts that are 10.9 grade minimum don't use 8.8's
Sure I started a thread on this I ordered 50mm long sicken head bolts and cut them down to 40mm come from ebay
Old 19-10-2014, 09:25 PM
tlr_rst
tlr_rst's Avatar
I've been searching all night and getting deflated that some say it wont fit on standard erst wheels others say it will with bringing but is not strong
is a spacer a circular plate with holes in cause when i type 12mm wheel spacer on ebay it shows up.
where the callipers 2 bolts bolt to, is that called the hub??? if so how does the circular 12mm spacer help
im so confused
Old 19-10-2014, 10:06 PM
Chopshop85
Chopshop85's Avatar
The spacers are basically 12mm thick washers.
They sit between the caliper carrier and the hub.
If you offer up the discs, then slide the caliper onto the disc, you'll see a gap where the bolts go.
You'll also need to grind down the calipers if you are using standard wheels.
Old 20-10-2014, 06:22 AM
tlr_rst
tlr_rst's Avatar
great that has helped a lot, as i was looking at 12mm spacers on ebay which seemed to bring the wheel out if you know what i mean, now i know they are 12mm washers that helps loads. and fit between the hub and calliper.
so i can look for these now, i also understand i must drill the hub holes out to 12mm as thats what the mondeo callipers are.
and i now understand i need M12 bolts that are 40mm long and 10.9 grade in strength
are these blots ok: LINK
also if I'm using the standard 15" wheels and shaving off the areas I've found in a guide, will it be weakening the callipers??? the ridges on metal that protrude strengthen metal, and I'm concerned about this.
maybe a wheel space might be a good idea bringing the wheel out a little to save grinding the calliper?? then all i need is longer wheel bolts.
let mew know, i need your help guys as i going to do a step by step guide with photos for others here on using the standard wheels with this conversion if you want to help
Old 21-10-2014, 07:56 PM
marky_g
Fleet Manager
marky_g's Avatar
No you don't need wheel spacers or Hub spacers just a 12mm think piece of material to bring the caliper Central over the st170 disc
Those bolts are perfect for the job try doing a search on here as me and matty325 had a meal getting bolts
Fyi there's a guide with pics but for a puma I think
JasonPD
Ford Focus RS
20
31-10-2015 08:11 PM
liamT74
23-09-2015 10:24 PM
Brickhouse
20-09-2015 11:47 AM
Russp
Escort Range
18-09-2015 07:39 PM
fordfiestamk3
11-09-2015 12:52 PM
Quick Reply: got mondeo mk3 callipers struggling with bolts
