pic request mk4 escort lowered 60mm
With the British roads i had to get mine put on 40mm springs. I had mine around 60mm, handling was fine but then you constantly driving drunk to miss holes and lumps,rises in the middle of the road where it dips on the tyre tracks. Other than that it looks the nuts and good for track use? Beware of tyre wear if you using standard arms etc.
Hope your spax springs lasted longer or are still ok compared to the two sets i went through within a year of each other. I must of had two bad batches . Both snapped on the front. So ever since i've been with pi springs now with no trouble.. thought i'd share this just in case anyone else had problems with snapped spax springs.
Hi mate, surprised you remembered the problem I had with those springs, haven't done that much mileage since i had them fitted but so far there been alright thanks for asking.
However, they did replace them without any hassle. and the replacements seem to be holding up alright.
For some reason they didn't want to replace mine straight away and it was quicker to order another set, which was a silly move at the time.. The springs are powder coated. Trouble is i know exactly what they done wrong as i do it as a job. Seems they skipped the pre-treatment of the metal or the chemical levels for the metal, where its way to high before painting. This leaving no protection what so ever and when the springs move over time the paint comes off brittle,flaking etc. Then get the issue of salt and god knows what eating into the springs when driving.
Coilover's yes i have been looking at gaz? gaz gold i also came across but think this overkill and the car is road use. Never been on track even tho i'd like to get it on there one day for bit of fun.
AVO are good quality for the money, again depends what use the vehicle has. I fitted coilys for the first time on my daily drive S2 rst. If im out prowling I can drop them a tad and really enjoy the cornering or commuting to work and back I can raise them up a touch and soften my early mornings
