rocker cover gasket, cork or rubber???
Old 02-01-2014, 09:05 PM
tlr_rst
tlr_rst's Avatar
Default rocker cover gasket, cork or rubber???
hello
apart from finding a leak in the distributor i think also the cork gasket maybe leaking from the front. Its away from the dizzy and high up so i suspect this. It was new on 2 years ago by previous owner and its done 7k miles since my ownership
whats the best gasket to get, i see ford used a cork, but i hear others saying use the rubber. can you all please help me with the best option
many thanks
Old 02-01-2014, 09:13 PM
I use rubber ,have done for years off the 1800cvh
Old 03-01-2014, 08:37 AM
tlr_rst
tlr_rst's Avatar
ok thanks fella, i ordered a rubber one last night, are they tightened like pinch tight or just so it nips?
Old 03-01-2014, 12:02 PM
mentalasanything
mentalasanything's Avatar
I found the rubber one completely useless. Each unto their own I think but I've never had a cork one fail.
Lee
Old 03-01-2014, 01:20 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Rubber one needs a little bit trimming off in places too, they have metal inserts to prevent over torquing just like genuine cork ones.
Old 03-01-2014, 01:24 PM
It's Czech Mate
It's Czech Mate's Avatar
Genuine Cork for me every time, not a pattern one, if it still leaks then the rocker cover is warped probably
Old 03-01-2014, 02:30 PM
haz87
haz87's Avatar
Cork all the way on normal CVH rockers. The only one ive found that works well on rubber is the Rs1600i cover
Old 03-01-2014, 02:37 PM
darrenb16two
darrenb16two's Avatar
Always used rubber ones and never had an issue, Can be reused aswell
Old 03-01-2014, 02:44 PM
moesin2005
moesin2005's Avatar
i had fitting issues with a rubber one
Old 03-01-2014, 03:53 PM
It's Czech Mate
Probably because your rocker cover was warped as they have a tendancy to do that and the rubber gasket lets you get away with it to a certain extent
Old 03-01-2014, 04:05 PM
gus
gus's Avatar
Rubber for me too
Never had an issue and looks good to imo
Old 03-01-2014, 05:53 PM
tlr_rst
tlr_rst's Avatar
hi guys, well i ordered a rubber one thought id give it a go as the cork didn't last long.
how tight am i meant to tighten it can you please advise???
Mark RS
05-03-2021 06:08 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: rocker cover gasket, cork or rubber???
