For anyone interested in fitting Corsa D power steering... ON HOLD :(
Thought it was time to get it sorted so bought a complete 58 plate Corsa D column for £90 off the bay, should be here in a few of days...
Will update with pics etc. as I do it!
I know Gary and Rick have done this already but though I'd stick up a guide thread for others to see too, any hints and tips from you two would be appreciated though fella's!
Oh, if anyone has a stock column and shaft lying around drop me a PM, need one to butcher the Corsa unit into! lol
Yeh I did notice that, tbh for what they cost if one did fail its hardly massive expense to replace it. the hard bit is making it fit then its plain sailing from there.
first thing we did was smash all the barrell etc of the thing to get to the heart of the beast then cut the top part of and re welded the escort one on to it so all the escort stalks etc could be used then offered it up in place to see where to then cut lower part of escort one to get it back to standard lenght for steering wheel position then welded it so basically you now have the corsa one as a sandwich in escort one then welded tabs onto it to bolt to car to stiffen it all back up and take the load placed on it when driving hope that gives you a quick rough guide to get you on your way
From what I can make out from other pics the ECU is built in to the center section by the motor, and just needs a RPM signal, and speed signal, plus obviously your normal live and earth.
So RPM is easy, speed signal I will try from the speed sender on the gearbox, if that doesnt work then there is a guy on ebay that sells a little control box that plugs in and simulates both.
we use the little control box off ebay. Didnt get done till late last night (in the garage lol) so didnt get on my pc ,on my phone in work hours .
The two columns side by side...
Thinking about just having the first knuckle joints swapped over, using the RST bottom half fitted into the top half of the Corsa kuckle..
Then just cut and sleeve/weld the top half of the RST shaft to the Corsa one, if you remove the outer sheath of the Corsa column there is just a normal size shaft in there.
Have not got my car right now to see where that would sit the motor etc. in relation to the dash (having a new battery tray fitted) but these are just my first thoughts.
Also here is a pic of inside what looks like the ECU part...
Need to find out what pins do what on the multipin socket you can see, the two bigger spade connector ones are for the power and earth I guess, and the one that is still plugged in is for the torque (steering wheel) sensor in the top half of the column.
Karlos, I trusted mine to a pro welder, ie. Gary - make sure you do the same as you don't want the bastard snapping on you mid bend...
It's an awesome conversion though. Trickiest bit is getting the lengths spot on, and then making nice strong brackets to keep the top half study.
Rick
Rick
Decided to leave this until the spring, instead my money is going on a new tacho, speedo, fuel, and water temp gauges to match my, oil press, temp, and boost ones!
Speedo cable broke the other day and i'm fed up with having a wobbley needle anyway so a good excuse to change the lot! lol
That's potentially very dodgy..
Whoever made that has cut out the "collapsible can" safety section from the original Escort column. The whole point of it is if you have a front ender the steering column will collapse into the dash if your chest hits the steering wheel. With that section removed the column won't fold and your ribcage will collapse instead.
I'd rather have the collapsible section than PAS if it has to be one or the other. PAS isn't going to be much good to you if you're dead...
Thanks
Paul
I'm not convinced the collapsable can as you say does much. The steering wheel is bolted to the inner column which is solid anyway.
Rick
