Oil pressure and oil temp gauge
for the oil pressure you can buy a t piece that goes where the original oil pressure switch is, this will make way for the new sender and also keep you roriginal pressure switch for the oil light
the oil temp, i was using automter and it came with adaptors that replaced the sump plug so put mine in the sump
basically the sender is the sump plug from then on but you can also buy an adptor to put in an oil line for the sensor
hope this helps
hope this helps
