Escort Cosworth oil pressure sender.
Old 13-07-2014, 09:41 PM
rcr
rcr's Avatar
Default Escort Cosworth oil pressure sender.
Hi,a friend trying to find a new oil pressure sender for a 93 Escort Cosworth. It has VDO stamp and a Ford part number on it.Ford dealer could not find it in the system. Can he use any type of VDO oil pressure sender with 0-5 bar? Many types of them on Ebay.uk etc.
Old 02-08-2014, 06:55 PM
opposite lock
opposite lock's Avatar
http://shop.motorsport-developments....itch-172-p.asp
http://shop.grahamgoode.com/oil-pres...68-69433-p.asp
http://shop.grahamgoode.com/ggr-oil-...35-70895-p.asp
Tee piece if needed.
Old 02-08-2014, 08:35 PM
Escos Jam
Escos Jam's Avatar
I don't think they switches work on an Escos. The Escos switch is different from a 3 door and sapphire switch.
Old 02-08-2014, 08:38 PM
Escos Jam
Escos Jam's Avatar
http://www.etbinstruments.com/Sensors_ancillaries.htm
This is the one you want. 3rd from the bottom in the VDO section.
Old 02-08-2014, 08:53 PM
opposite lock
Well done mate , didnt realise that being same block I imagined to be the same.
Vincereese
01-06-2023 09:14 AM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Escortdriver1
31-07-2015 02:36 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Escort Cosworth oil pressure sender.
