Uprated Fuel Pump??
Old 20-02-2008, 10:19 AM
auralisRS
auralisRS's Avatar
Default Uprated Fuel Pump??
Hello all
Does anyone else run a ST Escort with GG 305 conversion with standard fuel pump. Standard injectors, SS exhaust , no cat..K&N...
Car goes fine, just wonderered if it would go better with a Higher pump fitted.
any thoughts
Old 20-02-2008, 11:02 AM
cossymad
cossymad's Avatar
Mineran fine on std pump, it was only when I changed for omex and bigger injectors, I changed the pump
Old 20-02-2008, 03:03 PM
Kelv
Almost there!
Kelv's Avatar
as long as the pump isnt tired, is recieving a good 12v supply and from that it should be flowing at the correct rate then there is no reason why you should have any concern.
Failing that, an 003 pump is a direct upgrade replacement and will ensure you have sufficient fuel supply.
oh, and i have one of those for sale
Old 20-02-2008, 04:58 PM
llw
llw's Avatar
on the gg305 conversion, how well is well
im thinking about gettn this done, but dont want to spend the money7 and then find it boring and change to big turbo
rather just change to bt now
Old 20-02-2008, 06:36 PM
ECOS95
ECOS95's Avatar
For the sake of £80 I'm going to replace my standard 13yr pump with a Walbro 255ltr pump. Should be good enough for my 350 BHP goal.
Old 22-02-2008, 03:04 PM
fudaga
fudaga's Avatar
How much for that pump please? is it new and can you send it to belgium?
greetz
fudaga
Old 22-02-2008, 03:25 PM
Kelv
Almost there!
Kelv's Avatar
its up for sale at £60, was on my car a litle over a year, so probably covered about 4000 miles (ish).
ill gladly post it anywhere you wish mate, as long as postage is covered.
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Uprated Fuel Pump??
