weird escos troubles
hi all
i have a weird problem with my escos,
it only revs up to 4000 rpm and only givs about 0.5 bar off boost, what can this be?
sometimes i goes like it should, but after 2 or 3 times i keeps hanging up at 4000 rpm again, its a big turbo cos.
things i was thinking about that could be wrong are
-ECU
-Chip( getting another one this week)
-actuator
-vacuum leak?
do you have any ideas? or had this yourself?
regards
roy.
-ECU
-actuator
-vacuum leak?
regards
roy.
well, now your all saying something else , i change the chip and ecu first and then ill see if sorted, i already know about the problem with the 2 main loom connections, but they are still in good condition on mine,
ill keep you posted
ill keep you posted
I would try swapping sensors first as the ecu is SUPPOSED to do that fault if one of the sensors is down.
Have you got a mate nearby with a working cossie? Get him round and do some swapping!!
yeah swapping isnt a problem, you know of jp-cars in the netheralnds? its family, so that wont be a problem
I have yes, saw them at landgraaf, 2 years running when I was in germany!!
In that case may as well nick an ecu as thats easiest to change lol!!
Re: weird escos troubles
hi all. still having troubles with my escos.
already changed:
-ECU
-Chip
-Crancksensor
-Lambda
-Map Sensor
-ignition
but its stil in safe mode
anyone with any ideas???????
already changed:
-ECU
-Chip
-Crancksensor
-Lambda
-Map Sensor
-ignition
hi all
-ECU
-actuator
-vacuum leak?
regards
roy.
-ECU
-actuator
-vacuum leak?
regards
roy.
Roy, since this ecu is in limp home mode, you must be able to read one (or more) troublecodes. So, first thing is to get the codes read. A simple led-tester will do that, but you can also use a star-tester. Then you know which circuit (doesn't have to be the sensor itself, can be wiring loom also) is causing the problems. Saves you a lot of time searching and trying.
Other way of testing is using a break-out-box and checking the signals with a DVOM.
