No boost BT Escort
No boost BT Escort
I have recently had my head off, as the lugs on the head were the inlet manifold bolts through had snapped. Now it's back together, it doesnt make any boost. It only just gets to Zero bar boost. This must be something simple but cant see anything obvious wrong in the set up. Any suggestions please on things to check. This is really doing my head in, as I've spent hours going in circles.
Thanks
Thanks
Thigs to look at
Boost leaks?
Wastegate opening and shutting corectly? and connections?
Actuator preload?
boost gauge reading correctly?
Throttle opening fully?
Boost leaks?
Actuator preload?
JK12
33
26-04-2021 12:09 PM
