removing lower rear spoiler
Old 10-02-2007, 05:52 PM
Steve Escos
Steve Escos's Avatar
Default removing lower rear spoiler
as title how does this come off the bootlid? Need to take it off to check underneath.
Cheers Steve
Old 10-02-2007, 06:47 PM
THE RADMAN
THE RADMAN's Avatar
get a BIG hammer and chisel steve if i remember correctly you remove a rubber blanking plug each side in the boot shut area of the boot lid for access to 2 bolts and remove the plastic trim in the bootlid for access to the other 2, or something like that ,theres 4 bolts in all,youve already got the top spoiler off havent you?
Old 10-02-2007, 06:50 PM
THE RADMAN
THE RADMAN's Avatar
make sure the drainage channels in the spoiler are clear whilst its off and i should also use a blob of silicon around the holes [inc middle one]when you refit to make sure its water tight,or your tent might get soggy
Old 10-02-2007, 07:41 PM
redrsmk5
redrsmk5's Avatar
Originally Posted by THE RADMAN
get a BIG hammer and chisel Steve if i remember correctly you remove a rubber blanking plug each side in the boot shut area of the boot lid for access to 2 bolts and remove the plastic trim in the bootlid for access to the other 2, or something like that ,theres 4 bolts in all,youve already got the top spoiler off havent you?
What he said! .....Very fiddly to get them out but one piece of advice on this is use a magnetic philips screwdriver because if you drop them in the tailgate you will have fun gettin them back out!!!
dont overtighten the centre post when putting the tail back on or it'll crack at the base.
Old 11-02-2007, 09:08 AM
Steve Escos
Cheers for the advice. Now wheres the hammer and chisel LOL
3drRich
13-09-2015 07:32 PM
mint_s2
02-09-2015 08:58 AM
no1trancefan
Ford Focus ST
30-08-2015 08:20 AM
29-08-2015 08:16 PM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: removing lower rear spoiler
