FAO people with floating disc's
Old 03-02-2007, 11:41 AM
Rolls
Rolls's Avatar
Default FAO people with floating disc's
Hi guys - got a question for you all.
My car has 355mm floating discs, and it seems to occasionally have a knocking like noise when you are driving it, coming from the front nearside..
it doesn't do it when you corner, doesn't do it at low speed (although the disc's do obviously move about and make a bit of noise), but it does seem to to it at higher speeds on the m/way - say at 60 or 70 mph - it almost sounds as it you are driving constantly over small cat-eye's....
I've just taken the wheel off, to check everything, it it all seems to be ok - but the discs to seem to be able to move a fair bit - and 2 of the bolts on the face of the disc have lost their little washers so that are moving about more too... - how lose should all of the bolts be for the disc's? - do they seen to be "set'up" periodically, or are they fit and forget?
cheers for any help
Rich
Old 03-02-2007, 03:41 PM
NUTS RuS
NUTS RuS's Avatar
Which bolts you on about ?
The disc to bell bolts?
They should be 11-14 Nm and should use the clinch type nuts so they dont come loose
Old 03-02-2007, 03:47 PM
Rolls
Rolls's Avatar
Yep - they're they kiddies...
I'll get some pic's in the morning as to how "loose" they are.
I did have a look on AP's website but it appeared to be about as clear as mud
Old 04-02-2007, 11:50 AM
Rippers
Monte Geek
Rippers's Avatar
Mine came with this written on them
Old 04-02-2007, 01:00 PM
Rolls
Rolls's Avatar
lol - ok - i'm guessing that the bolts aren't actually loose? - as on mine you can move them around - 2 ticks, and i'll get a pic...
Old 04-02-2007, 01:11 PM
Rolls
Rolls's Avatar
righty - 2 pic's - showing just how much you can move the bolts about, and the second showing the lost washers... - i'm guessing that a phonecall to Mr Rainbird will be in order to get some new bolts, and get them tightened up correctly????
Old 04-02-2007, 01:23 PM
Azrael
Azrael's Avatar
This looks dangerous....
Old 04-02-2007, 01:49 PM
bige
bige's Avatar
dont drive with the car before you change ALL the bolts - disk can explode
Old 04-02-2007, 02:56 PM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
mate dont drive it like that!!! you need bolts ASAP
Old 04-02-2007, 03:06 PM
Rolls
Rolls's Avatar
ritey - probably just as well that i only drove to the petrol station and back, and don't use the car at all during the week etc...
New bolts will be on order tomorrow
Cheers for the info peeps!
Old 04-02-2007, 05:57 PM
Damo V
Damo V's Avatar
Have the bolts not worn the holes in the bells?? looks like it??
Bet if you take them all out those holes have been elongated/worn...
Old 05-02-2007, 10:39 AM
DaveEscos
DaveEscos's Avatar
that looks FUCKED
where are the gubbins for the bells?
Old 05-02-2007, 11:10 AM
Rolls
Rolls's Avatar
T'is odd - its only the 3 that are next to each other that have gone like that. the other bolts can move a tiny bit (you can't get a finger nail behind them...), but no-where near as much as those 3 - new bolts and gubbins are on order so i'll have a proper look at it at the weekend!
Old 05-02-2007, 01:47 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Just seen this post and didn't realise that it had gone like this .
You may need new bells afterall . You need to check and make sure that any of the holes in the bell are NOT ovalised. They need to be circular, if not, you need new bells . Regarding the holes for the bobbins (or "gubbins" as Dave calls them ) that go on the disc itself, they should be slotted (elongated with flat sides) for the bobbin to float in.
Old 05-02-2007, 04:50 PM
DaveEscos
DaveEscos's Avatar
ok ok , bobbins!
Old 06-02-2007, 05:52 AM
mcossie
mcossie's Avatar
Default Re: FAO people with floating disc's
Rich
What do you say, you are floating disc??? bells and discs are one part (when bolts are new...). This are special calipers?
Old 06-02-2007, 09:31 AM
Mike Rainbird
Caraholic
Rich
The disc has slots for mounting points instead of holes, so they are not fixed solidly to the bell, they have freedom of movement (which makes them rattle at slow speeds).
Old 06-02-2007, 09:43 AM
Azrael
Azrael's Avatar
mcossie those are floating discs - at this size fixed disc would cause vibration very quickly.
Old 06-02-2007, 10:03 AM
dojj
Resident Wrestling Legend
dojj's Avatar
does this mean that you can retrofit them little washer things to a set of discs and have them float too?
Old 06-02-2007, 10:32 AM
Mike Rainbird
Caraholic
No, as floating discs have to have SLOTS for mounting onto the bell and not circular holes.
Old 06-02-2007, 10:43 AM
mcossie
mcossie's Avatar
I said that because I want to fit AP 355/32 discs with porsche 996 4 pots calipers...
I make a mistake???
Old 06-02-2007, 10:59 AM
Mike Rainbird
Caraholic
I make a mistake???
In that size, they should be floating to avoid pad knock-off. This occurs in hard cornering when the wheel bearings flex and due to the size of discs (and depending on which way the car is corning) will lean on the pads and push one of the top and on one of the bottom pistons back (diagonally opposite each other) if they are fixed bells. What then happens is the next corner, you have no brakes (without furiously pumping the pedal to get the pistons back out ). With a floating arrangement, this has no effect on pistons, as the bell can twist and flex independantly of the disc.
Old 06-02-2007, 11:40 AM
mcossie
mcossie's Avatar
it's difficult to change fixed disc in floating disc... simply the bolts???
Old 06-02-2007, 03:05 PM
Mike Rainbird
Caraholic
You need a special type of disc with slots instead of holes where the disc mounts to the alloy bell.
If you don't intend on REALLY hard cornering (like track days), you should be okay, but you absolutely must NOT go beyond this size with solid mounted discs IMO.
Old 06-02-2007, 04:53 PM
dojj
dojj's Avatar
good desrpition there but:
how does this effect peeps who run 330mm discs then mike?
are they ok as non floaters or would it be advised that they turned to floaters as well?
or is this for cars that are running bigger than the 330mm's that the majority tend to run?
Old 06-02-2007, 04:55 PM
Azrael
Azrael's Avatar
dojj even many standard cars are affected by this problem, you can see this on BEst MOtoring videos when they press brake pedal on long straights with left foot to cancel pedal free play before hard braking.
Old 06-02-2007, 06:04 PM
GUZZLER
GUZZLER's Avatar
Mike, do have any pics of the 'bobbins' ???
Old 06-02-2007, 06:06 PM
THE RADMAN
THE RADMAN's Avatar
i dont want any floaters
Old 06-02-2007, 06:46 PM
Mike Rainbird
Caraholic
Doesn't become as big an issue until the discs get much bigger. Just imagine a small ruler and pivot it about it's centre, then get a much longer one and pivot it the same amount, the movement at the end due to it's increased length is dramatically increased. Same principle with big brakes .
Guzzler,
Will put some pictures up tomorrow .
Old 06-02-2007, 08:28 PM
Franco
Franco's Avatar
Dont worry Rolls, mine did exactly the same!
I wasnt blessed with the torque measurements on the disk, so tightened them up rather well!
My bells have become ovalised, but speaking to Martin H he said they should be fine (i will be replacing obviously!!).
Jason
Ps - We all make mistakes mate!
Old 06-02-2007, 08:36 PM
Rolls
Rolls's Avatar
Yeah - just pleased they will be easy enough to replace... - got new bells, and bolts / bobbins on the way (Well...as soon as i get to Barclays to transfer the money to Mike - Poxy traders not having a clue with exchange rates stopped that today )
Old 07-02-2007, 05:18 AM
mcossie
mcossie's Avatar
I saw on AP range, there are 355 bolted and floating discs... but all the 378 are floating...
I use my escos for track day, so I'll try to fit the 355 bolted...
Thanks all
Marc
Old 07-02-2007, 07:11 AM
Franco
Franco's Avatar
II use my escos for track day, so I'll try to fit the 355 bolted...
Marc
No Marc you need floating for track days! not bolted!
Old 07-02-2007, 07:15 AM
mcossie
mcossie's Avatar
Mike said that it is possible !!!
Old 07-02-2007, 07:26 AM
Franco
Franco's Avatar
Yes but didnt advise it!! Due to cornering speeds on track!
Old 07-02-2007, 07:37 AM
Mike Rainbird
Caraholic
I have my very own secretary bitch .
Cheers Jay .
Now make me a coffee (and bring it back to bed ).
Old 07-02-2007, 07:43 AM
Franco
Franco's Avatar
Get your elbow out me back retard!
Ps i'll be going to source for my bells/bobbins this time Mike - i know you'll understand!
Old 08-02-2007, 03:48 PM
Franco
Franco's Avatar
Update to make Rolls feel better..........
I had to strip my bells off to send up to Martin yesterday, ended up loosing most of the skin on me knuckles, and having to smash shite out of the bolts with a hammer to get out of the bells (i'd tighten one bell up so tight, one bolt sheared!).
Old 08-02-2007, 09:59 PM
Rolls
Rolls's Avatar
LOL! - well, i'm now just awaiting delivery of my nice new shiney ones.... - oh the joys eh!
So.................
on that note - how often should you tighten /check the torque on these buggers?
Old 09-02-2007, 09:53 PM
Franco
Franco's Avatar
Didnt think you'd need to being honest................ Dab of thread lock should sort that (arnt the nuts nylon lined??).
Quick Reply: FAO people with floating disc's
