P8 wiring diagram
Well actually I know what pins are used I really need to know what order on the tps plug they go to ecu if that makes sense. Im using a 2wd loom and I know that 2 wires need swapping just cant remember what ones
Yeah thanks alot I think I may have solved it comparing a diagram i have for a group a cossie and 2wd one but rather be sure so any info would be appreciated thanks
Im using p8 loom pf09 tps and 2wd loom. From what I can make out i need to swap pin 17 and 30 round and the final one on the sensor stays where it is but this is where i wanted to be sure.
Mark RS
12-10-2015 06:01 AM
