Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Rs2000 fuse box
Old 02-09-2014, 08:27 AM
Fordmad!
Fordmad!'s Avatar
Default Rs2000 fuse box
Right got my rs2k sorted now after a leak onto the fuse box.
Its up and running and found it needs a new scuttle panel.
Few question
1. Ive put a bag over the box for now will that be okay as a temporary measure until I can sort it properly? It wont melt or anything stupid?
2. Can you weld up or replace the scuttle without having to completely take the dash out? Just free the dash and pull it clear of the screen, cover it and repair the scuttle?
Old 02-09-2014, 12:40 PM
Moderator
STeve's Avatar
I would use a rubber floor mat cut up to fit over the fuse box rather than a bag as a bag will attract moisture, as for welding depends really on what parts are in that area but a escort mk6 dash is dead easy to remove anyway
Old 02-09-2014, 05:46 PM
Fordmad!
Fordmad!'s Avatar
Yes I did wonder about moisture with a bag. Ill sort out something else. Yeah ive took a dash out of a mk6 before its easy enough even better if you don't have to!
Only reason I don't want to take it out is that the immobiliser wires are attached to it and don't really want to cause anymore problems.
Old 03-09-2014, 06:34 AM
Moderator
STeve's Avatar
just a few cables ties and hey presto
AJC
08-10-2015 11:09 AM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Rs2000 fuse box
