Wheels and Tyres Wheels and Tyres for all Ford's
Tyre valve leaking, never had this before?
Old Apr 13, 2014 | 11:13 AM
BM08's Avatar
BM08
Default Tyre valve leaking, never had this before?
I dont mean from the rubber steam bit, thats fine, basically i was checking the pressures as you do, then i took the pump off the valve and the air just comes out as if your pressing the button with your finger nail, obviously this is stuck in, ive tried moving it with a knife/pen and putting the pump back on and off but its just pissing out
The only thing stopping the air is the valve cap thats screwed on, why does this have to happen on a sunday
Can it be unstuck somehow or is it to the garage and new valve time?
Old Apr 13, 2014 | 11:50 AM
JayCC's Avatar
JayCC
Wouldn't mess about with it, for the sake of a few quid it'd be a new one for me.
Old Apr 13, 2014 | 11:52 AM
STeve's Avatar
Super Moderator
if you have a valve key simply unwind it out and fit another from a spare wheel etc
Old Apr 13, 2014 | 11:55 AM
BM08's Avatar
BM08
Didnt even know it winds out lol
Ill have a play around with it later, if not ill just have a new one fitted at the tyre place then, just abit annoying when its your only mode of transport
Cheers folks
Old Apr 13, 2014 | 11:58 AM
STeve's Avatar
Super Moderator
yes mate they simply wind out so simple diy fix
http://www.ebay.co.uk/itm/4-WAY-META...item1e73591d92
Old Apr 13, 2014 | 12:07 PM
BM08's Avatar
BM08
ahhh i see what you mean now, brilliant cheers for the link
Old Apr 13, 2014 | 01:47 PM
lacey's Avatar
lacey
It happens a bit on the alloy valves you can get but you can normally sort it by letting the air out and put a drop of oil in the valve then pump it up
Failing that then do as above
Old Apr 13, 2014 | 02:08 PM
BM08's Avatar
BM08
Good tip that, wouldn't have thought you could put oil on it, I guess it won't hurt.
Anyhow, I've managed to play about with a screw driver and get the little button to pop back out and stop the air as it should. Won't be touching it until I get it sorted properly
RS-Rikki
Sep 21, 2015 07:27 AM
talon1
Sep 15, 2015 10:27 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
3dr cossie
Sep 2, 2015 08:58 PM
