Wheels and Tyres Wheels and Tyres for all Ford's
Mk1 sierra et38
Old Mar 4, 2012 | 10:50 AM
rsstav's Avatar
rsstav
Default Mk1 sierra et38
Hi bought a set of rs7 softlines et38 will they fit my mk1 sierra with cosworth front bed and brakes with 205-40-17 tyres
Old Mar 19, 2012 | 12:18 PM
V8ish's Avatar
V8ish
Im pretty sure the standard offset for the 15's is et38 so yes. Are TS7's 7 inch. You should be fine.
Ive got 7.5 (et30) front and 8's (et25) rear. You could probably go much lower offset unless you want to keep the standard sucked under look.
Old Mar 19, 2012 | 04:45 PM
D16PJM's Avatar
D16PJM
i thought they needed a spacer for the brakes to clear.
Old Mar 21, 2012 | 03:35 PM
R4N SS's Avatar
R4N SS
only need a spacer if using 2wd brakes and 2wd four pots - if using 4x4 cossie brakes then the wheels will go straight on
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
nico12
Dec 31, 2015 04:42 PM
IainRS1700T
Sep 25, 2015 06:44 AM
155lee
Sep 23, 2015 01:27 PM
PeterLucas
Sep 21, 2015 11:36 AM
