wheel offset?????????
Old Jan 27, 2006 | 02:05 PM
coley's Avatar
coley
Default wheel offset?????????
hello all just a quick question
if i have a focus rs 18x8 wheel with a 215/35/18 tyer and an off set of et42 what size spacer if any will i need to fit these to a 1989 2wd saph? also would the standard nuts/studs still be ok to use in this aplication? any help will be great
Old Jan 27, 2006 | 03:35 PM
Ben26's Avatar
Ben26
Alright mate,
u will need a 5mm spacer to take them down to et37. but i would never use a spacers really on a car like that.
The nuts will be the same as well 12mmx1.5
is the car running standard suspention, i ask only cozz if it is u will have to watch the top of the tyre on the under side of the strut on the fronts, thats why it has to be a 215 tyre and the correct offset
Hope this helps
Ben
Old Jan 27, 2006 | 04:37 PM
coley's Avatar
coley
the car is lowered but by how much im not sure, at the moment it has 17x7 and there is no tyre-arch conflict, mind you the tyers are only 205/40/17 do you think i'll need many arch mods to get them to fit
many many thanks for your help
Old Jan 27, 2006 | 04:47 PM
Ben26's Avatar
Ben26
when i had my cossy i had 7.5" x 18" wheels and i did roll the archs on the front as they did catch a bit and they were et37
Have a look
ben
IainRS1700T
Sep 25, 2015 06:44 AM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
Karl @ FPT
Sep 21, 2015 11:17 AM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
Adam Graham
Sep 6, 2015 06:04 AM
