Cam timing CVH
Old Jan 17, 2006 | 11:08 PM
mark-rst's Avatar
mark-rst
Default Cam timing CVH
Anyone know the timing and lift for a std cam on an RST?
Thanks
Old Jan 18, 2006 | 08:28 PM
JesseT's Avatar
JesseT
I'd like to make a good guess based on some assumptions:
inlet 0 btdc -> 36 abdc = 216 total
exhaust 42 bbdc -> 14 atdc = 228 total
Old Mar 12, 2006 | 09:37 PM
paconassa's Avatar
paconassa
haynes manual says:
1.6 litre (except carburettor versions 1986 onwards):
Inlet valve opens . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8° ATDC
Inlet valve closes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36° ABDC
Exhaust valve opens . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34° BBDC
Exhaust valve closes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6° BTDC
Old Mar 13, 2006 | 04:15 AM
JesseT's Avatar
JesseT
Originally Posted by paconassa
haynes manual says:
Those are the figures that Ford quotes for a mk3 XR3i. My numbers are the mk4 XR3i ones with the 4degree shift because of the different pulley.
Old Mar 13, 2006 | 12:52 PM
paconassa's Avatar
paconassa
versions 1986 onwards = MK4!!!!
Old Mar 13, 2006 | 02:24 PM
JesseT's Avatar
JesseT
Calm down mate, I can read. I'm marely stating that somewhere in our sources, there is an error. An interesting fact also is that eccording to the Ford's manuals almost all CVH models had different cams. However these are so close to each other that only one or two different spares are sold for all of them.
Old Mar 13, 2006 | 04:53 PM
paconassa's Avatar
paconassa
sorry mate... just bored!
check it out please, will you?
RUBY123
Oct 22, 2023 12:04 PM
Ben26
Aug 27, 2015 08:56 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
taylora1409
Aug 12, 2015 12:06 PM
