ARP Stud and Nut kit
Old Jan 10, 2006 | 02:54 PM
C0S_TURBO's Avatar
C0S_TURBO
Default ARP Stud and Nut kit
Hi I have managed to blow my head gasket again on my 2wd Saph. Is the ARP studs and Nuts reusable? I have thrown the instructions away, does anyone know the torque settings. I remember there were two as one was or the arp grease and the other for motor oil (which is better). I am only running 14 psi (MD67 turbo), RS500 intercooler, air filter and exhaust, not a huge power car, but this is my 3rd group A head gasket in under a year. I have had the head skimmed any ideas?
Many thanks
Old Jan 10, 2006 | 05:09 PM
sailorbob's Avatar
sailorbob
Yes, they are reusable (assuming you've not stretched them). The ARP instructions for my 190,000 psi 12mm stud kit says torque the nuts to 80 ft lbs when using ARP moly assembly lubricant. (or 120 ft lbs if using 30wt oil). The studs should be screwed into the block hand tight only.
Old Jan 11, 2006 | 07:50 AM
C0S_TURBO's Avatar
C0S_TURBO
Default Arp stud and nut kit
Thanks for those settings they will come inuseful this weekend. Any ideas on why the head gasket keeps going?
Thanks
Old Jan 11, 2006 | 08:44 PM
vyper developments's Avatar
vyper developments
Hi Mate,
obviously something not right here! Has it happened the same way every time? And when you say head gasket blown is it leaking water or has it blown between the cylinders? Or something else?
Mike.
Old Jan 12, 2006 | 07:24 AM
C0S_TURBO's Avatar
C0S_TURBO
Hi Mike,
It is leaking water, it always comes from under the exhaust mainfold and leaks down the side of the block, but not in the same place. First time round it was at the black near the bulk head and then near the front of the engine. Got hold of a second hand head and had it skimmed, it has now gone under the exhaust mainfold at the front of the engine. Every time I have replaced the head gasket I have made sure all surfaces are well cleaned. I have heard different things, some say put a little sealer alone that edge as the are prone to wear, some say don't put anything on. Your advise is greatly appreciated.
Many thanks.
Old Jan 12, 2006 | 07:28 AM
sailorbob's Avatar
sailorbob
A couple of things for you to check; Is the block deck flat? Has the head been overheated before, if so it could have softened and won't seal properly, get it checked for flatness and hardness.
Old Jan 12, 2006 | 08:39 AM
C0S_TURBO's Avatar
C0S_TURBO
Thanks sailorbob,
I have owned the car for 2 years now and to my knowledge the temperature has never gone into the red. Will the company that skimmed the head be able to check the softness? With the block, can I use a straight edge or will it need to been slightly more technical.
Many thanks.
Mike
Old Jan 12, 2006 | 08:47 AM
sailorbob's Avatar
sailorbob
Most good machine shops will be able to test the hardness. A proper straight edge with ground face is always best but you can probably get away with using a qaulity metal rule edge on.
Old Jan 12, 2006 | 12:32 PM
Azrael's Avatar
Azrael
If it's disorted you may need to have the block skimmed!
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
little bram
Sep 27, 2015 07:45 AM
