ESCORT COSWORTH DUMP VALVE
Old Jul 16, 2004 | 10:59 PM
Gerry Mac's Avatar
Gerry Mac
Default ESCORT COSWORTH DUMP VALVE
I WAS JUST WONDERING I WAS HAVING A PROBLEM WITH THE DUMP VALVE ON MY ESC COS AND WITH THE HELP OF SOME OF U GUYS WE WORKED OUT I NEED A TWIN DUMP VALVE BUT IVE GOT 2 SINGLE DUMP VALVES AND I WAS WONDERING WOULD THE 2 OF THEM FITTED WORK THE SAME AS A TWIN BUT SOUND BETTER ?ANY HELP WOULD BE GREAT
THANKS .
Old Jul 17, 2004 | 11:02 AM
wimwerf's Avatar
wimwerf
hello gerry,
yes I've helped you with the problem. having two dv is not the same as having double piston dv. there is a difference between a normal dv and one with a piston inside. for your escos you don't need a normal dv and also not a piston dv. you need a double piston dv. this means there are two pistons inside one dv. because your escos has a sensor which messures the air volume. on idle a dv is open so the engine sucks false air through a normal and a single piston dv. this is why you need a double piston dv. I hope you understand it now. if not please ask.
best regards.
Old Jul 17, 2004 | 01:23 PM
cosworth3d's Avatar
cosworth3d
i understand now
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
