oil light on on tickover
Old Dec 20, 2005 | 07:07 PM
cosbag's Avatar
cosbag
Default oil light on on tickover
my oil light flickers on when on tickover ive been told it might be my oil pump or the pickup is full of crap i wondered if anyone has had this problem and could give me some advice my car is a 1990 2wd c0ssie thanks
Old Dec 23, 2005 | 11:47 AM
SafeChav's Avatar
SafeChav
Duno, could be a dodgy pressure switch, worth changing it just incase it is the switch, only a few pounds, however unlikely but im sure you will be more pissed off if you take all the sump off and it is the switch!
Old Dec 23, 2005 | 12:55 PM
Azrael's Avatar
Azrael
May be old oil, failing bearings too :-(
Old Dec 23, 2005 | 10:04 PM
rssapphowner's Avatar
rssapphowner
time for a rebuild before it goes bang
Old Dec 26, 2005 | 09:15 PM
S1 Lee's Avatar
S1 Lee
sounds like the oil pump to me if the light goes out at anything above tickover.
check the switch connection first though.
if the engine sounds smooth and quiet chances are its the pump, either blocked or on its way out.
Old Dec 27, 2005 | 06:51 PM
PeterLucas's Avatar
PeterLucas
when bottom end bearings start to wear oil pressure is lost (particularly at tickover because this is when its lowest) but...
I had this problem with my rst turbo, i took the sump off to check the pick up pipe (sometimes the strainer gets blocked) but it turned out to be a weak oil pressure switch. Changed this (only a few quid) and now its ok.
Speaking to the partsman @ ford he said he sells loads. So theres a good chance it could be just a cheap sensor.
Good luck
Pete
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
