cossie bottom end
Old Nov 30, 2003 | 02:48 PM
croppy's Avatar
croppy
Default cossie bottom end
what parts would you need to have if you was to swap all internals from one block to another
could you get away with just a set of rings
all the bottom end is fairly new only done about 3k (bearings)
advise please
Old Nov 30, 2003 | 04:00 PM
Toe Knee's Avatar
Toe Knee
if ur leaving the pistons connected to the crank when u dismantle it then yea pretty much its just rings worth changing as a precaution. Depends why ur changin it all thou............................
Old Nov 30, 2003 | 04:03 PM
croppy's Avatar
croppy
cracked block m8 would leave the rods and pistons connected
Tank Mike
Sep 10, 2015 07:56 AM
Thanasis
Sep 7, 2015 07:33 PM
rsstav
Sep 7, 2015 04:43 AM
Ben26
Sep 3, 2015 07:55 PM
