Haeter Matrix and Fan switch
Old Nov 29, 2003 | 12:17 PM
Toe Knee's Avatar
Toe Knee
Default Haeter Matrix and Fan switch
Where are the fuses/relays for these in the fuse box in a cossie?!
The only fan related one i can find is no18 which is the heater fans but the fuse is ok and still not workin.
CheeRS
Old Nov 29, 2003 | 07:30 PM
steveRS's Avatar
steveRS
bttt for toe knee as i would like to know as well please
Old Nov 29, 2003 | 08:07 PM
RSrussell's Avatar
RSrussell
yeah me too
I remember someone saying the 30amp fuse and a yellow switch.
Dunno if this is right or not though
Old Nov 29, 2003 | 08:28 PM
Doug's Avatar
Doug
Toe Knee,
Toe Knee i think you will find the relay is situated behind the glove box a yellow one (there are two there but they are the same part no
And the fuse is also situated there if i remember correctly
Hope this helps
Regards Doug
P.S. if im wrong ask stu he'll know
Old Nov 29, 2003 | 09:15 PM
Hey, this is my first message on passion ford.
I've just bought a 4x4 cossie with a heater fan problem, in that it doesn't work. The fuse is number eighteen and is green (30 amp). I'm planning to check the fan motor tomorrow, as the fuse is ok.
I'll have a look behind the glove box as well, just in case.
Old Nov 29, 2003 | 09:37 PM
RSrussell's Avatar
RSrussell
Welcome to the site mate
cheers doug i'll take a look but i'm pretty sure that only applies to 4wd? maybe wrong though
Old Nov 30, 2003 | 04:46 AM
XR4Timan's Avatar
XR4Timan
Before doing that, i'd take the heater blower motor connector off and then plug it back in with the fan on with the ignition switch on. Chances are the connector is loose. Typical Sierra problem.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
