lowering a 4x4 sappy cossie?
Old Jul 9, 2004 | 06:24 PM
khaled's Avatar
khaled
Default lowering a 4x4 sappy cossie?
hi all,
i want to lower my 4x4 sappy, would like to know what parts to use, how much to lower it by for slik looks and good handling?
as you all may have worked out that im a dumb fooker, so please help
the car is to sit on the escos 16 alloys! plus any rough ideas of the kind of problems i am likely to encounter, along with what kind of £££ am i looking at?
i dont usually ask for much
thanks lads,
khaled
Old Jul 11, 2004 | 06:41 AM
richm's Avatar
richm
don't lower it any more than 1" - I used chassis dynamics springs to bring it to around the same height as 2wd. Any more and you have the potential for the front driveshafts causing you problems, and the rear camber becoming excessive.
The Escos rims won't do the handling any favours, as the offset is wrong
Old Jul 11, 2004 | 01:16 PM
Eagle's Avatar
Eagle
Super Moderator
im running some 8 x 18 inch compomotive rims .. mine is an inch lower .. but i have leda coilovers 220 lb rear and 350 lb front on an overall et35 offset...
hth
Old Jul 11, 2004 | 05:42 PM
khaled's Avatar
khaled
thanks for the advice lads
tib2220
Sep 14, 2015 12:33 PM
truffleshuffle
Sep 10, 2015 09:35 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
