cossie keeps dying on me
Old Nov 14, 2005 | 11:12 PM
thedaddie's Avatar
thedaddie
Default cossie keeps dying on me
driving along the engine cuts out, holding the accelerator pedal down nothin then sometimes it comes straight back on.if i try jump it when it cuts out nothin but turn the ignition off then back on starts straight away drives then cuts out again. it cuts out on tickover or when driving,hot or cold.
took me ages to get home
its had a new chip, plugs,grp a coil,dizzy setup 2 weeks ago been running great
Old Nov 15, 2005 | 08:18 AM
CosRush's Avatar
CosRush
I really wish i could give you s straight answer...but..........
I had the exact same problem as you........
And spent ages trying to diagnose the problem, one bit at a time.
Was getting nowhere in the end, and was getting fed up so ended up changing loads of bits at once...........and cured it. So i'll never know what fixed it.
But here's what i changed.
New CAS,
New Ign Amp (i thought this was the suspect)
New Phase Sensor
Probably of little use but hope it helps in some way.......
Old Nov 15, 2005 | 08:27 AM
cossied's Avatar
cossied
Default dying
a known prob is the wiring on the crank sensor it gets brittle after time, when mine was a prob I had the same symptoms cost about £25 I think
Old Nov 15, 2005 | 08:30 AM
rapidcossie's Avatar
rapidcossie
any smoke out exhaust while this is happening??
Old Nov 15, 2005 | 09:06 AM
CosRush's Avatar
CosRush
Default Re: dying
Yes, contact Matt Lewis on here......
He's got them i know, and a very helpful man he is too......
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
