HELP MK 3 Fezzy rear wiper
Old Sep 26, 2003 | 07:35 AM
razzyh's Avatar
razzyh
Default HELP MK 3 Fezzy rear wiper
this is really starting to pee me off
the wiper works fine then all of a sudden it will stop working.
Then the only way to make it work again is if you get a wire and where in the boot you connect the motor there is like a black connector and i need to join the 2 wires together then it will work but only for about 5 min
anybody have any ideas????
Old Sep 29, 2003 | 02:19 PM
razzyh's Avatar
razzyh
anyone???
Old Sep 29, 2003 | 07:41 PM
Stoned's Avatar
Stoned
It's usually a dodgy earth on the tailgate hinges
Make sure you do the following
1) clean up the contact pins and plates - use brasso or something
2) tap back the pins securing the tailgate door to the main body of the car. Stick a thin layer of castrol grease on em or similar and then tap them back
That should solve any electrical problems you are having with the tailgate. Especially the grease on the hinges, solved my tailgate remote release not working properly
Old Sep 29, 2003 | 07:59 PM
razzyh's Avatar
razzyh
i don't think its a earth problem as it works then stops even if i don't open the boot.
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
