my car is leeking
Old Oct 26, 2005 | 09:38 PM
rscozzysie's Avatar
rscozzysie
Default my car is leeking
i moved my car 2day and noticed the drivers side floor was wet
the back and passenger side r dry.it's a 2wd saff.
doe's anyone know what this could be.
cheers simon
Old Oct 27, 2005 | 05:52 AM
antony215's Avatar
antony215
Escort Rs Turbo
It might be your heater matrix gone mate
Old Oct 28, 2005 | 09:01 AM
gibbo frst's Avatar
gibbo frst
it was coming into footwell in mine ended up being the bung where the loom comes through the bulk head where its had wires pushed through..
Old Oct 28, 2005 | 06:29 PM
rscozzysie's Avatar
rscozzysie
it only doe's it when it's raining.i'll have a look at the bung
cheer's mate.
Old Oct 29, 2005 | 11:00 PM
kingpin09's Avatar
kingpin09
Default leak
ez m8 just 2 say ive got exactly the same proplem with my series 2...only thing is if you dont deal with it it will eventually work its way behind to the passenger side (like mine)..if you do resolve the situation i would appreciate it if you could let me know the solution. thanks
Old Oct 30, 2005 | 08:45 AM
antony215's Avatar
antony215
Escort Rs Turbo
Try the bung mate if it's not that then have a look at the sunroof pipes and makesure there not blocked
Old Oct 30, 2005 | 03:05 PM
Alvyn's Avatar
Alvyn
door rubber possible?
Old Nov 2, 2005 | 09:24 PM
kingpin09's Avatar
kingpin09
ive established my leak is coming from under the fuse box...any idea on how to deal with it (if it is the bung what do i do,is it a major job?)
Old Nov 4, 2005 | 05:53 PM
Alvyn's Avatar
Alvyn
remove the fusebox and use a sealant to seal the hole up or get the gromit
Old Nov 5, 2005 | 10:19 AM
kingpin09's Avatar
kingpin09
cheers mate will do!!
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Bailes1992
Aug 16, 2015 07:14 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
