brake bleeding on an s2
Old Nov 19, 2003 | 11:19 PM
tonyk's Avatar
tonyk
Default brake bleeding on an s2
Hi i have cossie 4x4 calipers 2wd discs and pads on my s2 and standard drums on the back, after fitting the system obviously needed bleed, but know i have no front brakes at all, the car holds and can stop on the handbrake ok. What is the correct way to bleed the car?
thanks
Old Nov 21, 2003 | 09:54 PM
tonyk's Avatar
tonyk
come on boys someone must know how to bleed an rst properly
Old Nov 21, 2003 | 09:56 PM
does it have abs?
Old Nov 21, 2003 | 11:16 PM
tonyk's Avatar
tonyk
mechanical std abs
Old Nov 21, 2003 | 11:40 PM
jack the rear of the car up and bleed as normal according to the haynes bible
Old Nov 22, 2003 | 04:49 PM
Neil S's Avatar
Neil S
There are valves in the ABS system that need to be bled out as well, but its 3 years since I last did this, so I cant remember much else lol.
The manual describes it in detail though Tony
Neil.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
