HELP MAJOR BATTERY DRAIN
Old Jun 6, 2005 | 07:52 PM
PAULDOLMAN's Avatar
PAULDOLMAN
Default HELP MAJOR BATTERY DRAIN
hi guys,
i've got a major battery drain on my fiesta rs turbo it's holding charge for about 2 days only i've had the battery & alternator checked which are both fine i've also disconnected the amp lead for the stereo from the battery.
any other ideas
PAUL
Old Jun 6, 2005 | 10:13 PM
Alvyn's Avatar
Alvyn
1st thing to do is disconnect the battery over the 2 nights/days and see if it will start when connected next day or if it's flat then the battery is no good
Old Jun 7, 2005 | 07:47 PM
PAULDOLMAN's Avatar
PAULDOLMAN
i've had a look at the fuse box on the fezz and there is a relay in the fusebox which has a thick brown and yellow wire
and a few thickish red wires which seem to be constally warm even though the car has'nt been run or the ignition has'nt been turned on witch i sure has something to do with the power drain
Old Jun 7, 2005 | 08:05 PM
Dave Henshall's Avatar
Dave Henshall
boot light, interior light..? heated window delay relay..? which relay number is it?
Old Jun 10, 2005 | 05:15 PM
turboloon's Avatar
turboloon
i've got exact same prob with my s2 i've disconnected a amp ,also my boot wasn't locking but managed to get it locked now (be a cunt to get open ...)
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
